Bravo drive question
I ran my boat all weekend no problems. Once on the trailer I gave both props a quick spin just to make sure it was in neutral. Starboard spun, no problem. Port seemed to resist a little and every revolution makes a "clunk" sound kind of like it is missing a gear tooth or something. However, I cranked it back up on the trailer put in forward and reverse and the prop spun and made no noise. Is this something I should concern myslef with at all? As I said previously the boat ran perfect all weekend right up on to the trailer Sunday evening. I just wonder if anyone else has experienced anything like this.
Are these alpha or bravo drives. If they are alpha drives then the clunk is normal and you have a drive that is slightly out of shifter adjustment. If bravo have them looked at.
Did you use muffs to start that motor or back it in the water? If not you fried your impeller in your sea pump.
About the clunking sound, that doesn't sound normal, check it out, like suggested above.
1BIGJIM
Drives and Lower Units
3
06-10-2008 12:46 PM
