Temperature "spiking" at start-up...
Location: Kentucky - where the women are so fast we have to put a governor on 'em!!
Mopower,
I just pulled the plugs last week, and none of them were as you described. They all looked good - slight chocolate brown color on the porcellain, maybe just a tad rich. First step will be to take a close look at all of the bypass hoses and passages.
Thanks for the help!
Toxic FORMULA
Bud,
Glad to here your plugs look good...but so did mine in the beginning Like I said , this saga went on for a couple of month and toward the end is when the plugs were white.At first , when the cyl. fired it blew a very little into the waterjacket and the water pressure wasn't enough to blow the other way so no excess steam or hydrolocking. I really hope you find something else stupid , but next July if your still fighting this problem , remember this. It drove me nutz for I don't know how long
Tom,
If the leak is sealing itself up once it is warm your plugs will look fine after you have run it. If the head gasket has a slight leak it could seal up once warm. Best to get a compression gauge on there so you have the winter to pull the heads if needed. Better yet lets rig up a leakdown tester and check all cylinders. Mopower may be on to something, check it out while it is a slight hangover instead of a major headache.
Toxic FORMULA
cp,
I couldn't justify pulling my own heads , particularly after drilling a couple of 1/8 holes in the 'stat to let the steam go by and allow the 'stat to sit in the water and function properly. I was too stubborn and lazy to do what had to be done. Besides that , I still wasn't convinced it was the problem when it was steaming out the pipes just that 'little extra'. You know , blame it on the weather...slightly cooler ...more humid.. or "well the engines not up to complete operating temp". I mean face it pulling the heads is a pain in the a$$! Especially if you don't know for sure . Not till it hydrolocked did I finally admit to it and pull the heads and found an ever so small rust mark at #5 between the water jacket and the cylinder.
Well, I wanted to run it this past weekend...
when it was warm, but none of my fellow boaters were going out! I guess that's a lame excuse. Now I'll have to break out the winter coat to run it!
Tim - we need to hook up anyway and try that outdrive swap sometime.
K-WELLS
Cigarette
4
07-27-2007 09:39 PM
mikesufka
12-26-2002 11:23 AM
