seawater pump impellers
Do all the BBC 572 cu. in. engines use a standard size impeller?......won't be removing the shrink wrap for a couple
of weeks and wanted to order new impellers before the old ones are out to compare.....also, what would be a good
quality impeller to buy?
The engine really has nothing to what sea pump is on it.
If its a standard Merc Bravo sea pump, they are all basically the same. The housing may vary, but they are interchangeable.
http://www.go2marine.com/search.do?a...ater+pump+kits
You'd be better off to just wait and see exactly what you have.
i tried the blue impellors years ago and did not like them.they don,t move water like the stock merc ones.
