502 mag MPI cooling system
Anybody know where bits of impeller end up in this model?
Straight to the heat exchanger or in the fuel cooler?
Can't get serial now but looks like a straight tube on top of the bell housing then fuel cooler.
Out of raw water pump,straight tube then fuel cooler?Sound right?
I think its a Mercruiser correct ? and what year model ? and what model 502 meaning is this a 502 Mercruiser MCM or MIE or in a jet boat app ? is this a completely OEM stock set up. all of this really matters to what exactly you have so all the guess work is taken out of the mix to get the proper answers to your questions.
and lastly your Engine serial number is ?
That sounds correct for most of them. Mine goes from pump to the oil cooler (across the bell housing) and them PS cooler only because it was modified. Yours would probably go as you saying without knowing anything else about the motor
Can't get serial but its a stock 502 MCM mag mpi.
By looking without dismantling(its a new motor) it looks like the fuel cooler is the first stop.
Does not look like a oil/power steer cooler on top of the bellhousing.Looks like a straight through pipe.
Just trying to work out where to look for debris after the raw water pump.
Thanks.
Just checked my manual and it is shown as being a power steering cooler on top of the bell housing.
Mine does not have this.It is a plastic straight through tube.Will get serial number.
If you have hydraulic steering you will not have a cooler. If it is a twin engine install, then only one may have the PS cooler
Well i just checked and i can find no power steering cooler.
Can't think that Merc would delete it even in a twin installation.
Serial is OLO17278.
Guess i'll have to fit one.
Serial is OLO17278.
The fuel cooler and the power steering cooler are non- restricted pass through designs ( no small tubes in cooler). Oil cooler should be first to catch debris. Good Luck!!!
