Newbie building a performance 454 needs experienced advise
#41
It is unofficially written in stone that people who have run the zz502 cam at bravo friendly rpms have had many enjoyable hours running sub 400lb spring rates. Nice lopey idle like the 731 cam . With carefully selected springs for what you personally are going to do with it , stock lifters (dirt cheap) will work fine.you will have to watch the initial set up , but with the type of exhaust your using , reversion can be avoided.
Still scratching my head how you have a mag block or rotating assy with flat tops . Something isnt right there and i wouldnt do anything else until you have positively identified your rotating parts
#43
At one point in bbc history , there was a abundance of cheap peanut port wagon and truck smog motors o'plenty. And it seemed like everybody had a top end from a grenaded ls6 or pre smog vette motor.
Everything had crappy compression , so how could it be any crappier ? The people said.
Just sticking a boat cam in a wheezer 230 horse 454 instantly brings another 100 hp to the table , so how about some real heads , a real intake and a skosh more cam ?
It just didnt work . . Everybody has forgotten . That was before the internet . People have moved on with their lives.
I would have to be standing next to a dyno where someone flips a 385 horse mag motor down to 7.8 to 1 and it still twists out 360hp then i still prob wouldnt believe it lol
#44
Flat tops usually came attached to 3/8 rods so if you got a forged crank and 7/16 rods with flat top pistons then thats all kinds of weird there. Ill bet you have a l29 .
#46
Flat top piston is a buzzword. Came from the small block guys.
"It's got flat tops, fueler heads, and a Harley double pump." LOLlllllllll.
Anyway, I would get a cheap boroscope if you don't have one and take a look at the top of the piston. You may even be able to see a part # on it.
Here are some smart phone boroscope's for cheap:
https://www.amazon.com/borescope/s?i...Ck%3Aborescope
#49
Being a non paying member you have to use another site to host them.
#50
The L29 Engines, used a flat top piston, but had a 100cc "vortec" head, which netted around 9:1 compression . The "mag" engines, used a small dome, and were still not 9:1, because of the typical 118cc bbc chambers.
