Fuel coolers
ignition problem and or --- possible coil ---- next time put an ice pack on the coil or blow a fan over it to cool it down - if the engine starts right back up - u most likely found your problem.
I have been out I lake test drives - then had no restart of the engine --- I have taken the blower hose loose and routed it to the coil and other ignition components to cool them down -- basically a layman test and for a possible restart of the engine. --- some worked for restarting the engine and some did not for other failed reasons. Just passing that along as possible tip for whomever.
