wet to dry conversion pipe?
does anyone make a stainless tail pipe insert to effectivly convert a wet pipe to a dry pipe?
Would be a flaired end 3.5" pipe to insert a 4" wet pipe?
Would be much cheaper than buying dry pipe , maybe 6 iches long to fit inmy Gill wet offshore pipes
speel chekk this fokker!
i think you need to weld up the water/exhuast mixxing holes and then put in 3/4" water pipes into the outer pipes that you would then plumb to through hull dumps.
if you are just tryng to get the h20 to mix lower then some kind of insert might work. I have a feelign if you go with an insert you need to find a machine shop to make that for you.
Pardon me, while I whip this out!
Jupiter Sunsation
04-27-2007 07:37 PM
wzmssf
4
08-08-2005 04:22 PM
