Comp cams Short travel lifters BBC
I have disagree that solids are "harder on the cam" and what not. Solid type lifters have been used in engines that have extremely long rebuild intervals. Many heavy duty / industrial diesel engines have utilized solid lifters, in both roller and flat tappet form. A caterpillar marine diesel, after the initial valve adjustment, the interval ranges from 1000 to 3000 hours.
You can have a solid roller camshaft that is very easy on parts, and have another one that is very hard on parts. Big difference between an endurance grind with 630 lift , and a drag race grind with 750+ lift. To me, pulling the valve covers isnt the end of the world. Its a bit tight on mine with the stellings headers, but its certainly not horrible. Even if once a year I had to loosen the headers a bit to get clearance. They also have 2 piece valve covers, etc. Its not like youre gonna have to pull them every weekend and check them. For most guys, once a season either in fall or spring . '
Hydraulics are not without issues. Tons of guys here have had issues with hydraulic lifters of various brands. Alot of guys are building big power these days, and dont wanna deal with adjusting the valves, but in reality, arent getting the life out of the engines they think they will. Meaning, building a set of 1000s, and think they are gonna go 300 hours without touching anything and just put gas in the thing and go boating. Thats pretty rare.
Theres a lot of variables when it comes to hydraulics. How much rpm can they take, what grade of oil, what oil temperature, are they pumping up or bleeding down at higher rpm, etc. And no, you wont know if something like a valve seat is getting pounded into the head, or a valve getting a slight tulip to it, or a worn cam lobe, until the damage has spread thru the engine like cancer.
Crane solid roller 304/312 254/262 at .050 with .636/.636 lift
Crane solid roller 286/294 254/262 at .050 with .714/.714 lift
which one ya think is gonna be harder on parts?
When someone makes a blanket statement saying I've never had a problem therefore there's no problem, that doesn't necessarily mean there is not a problem.. Not picking on you Tim.
Yes, the valve seat/face surface is moving ever so slightly vertically, I dunno If I'd refer to it as moving; degradation maybe; getting tighter buy burying the face. That's what requires the adjustment on what I'm working on.
I built a turboed SBF engine for my street car almost 10 years ago. I know it's not a marine engine or BBC but when I built it I had reliability and low maintenance as top priority. I went with a solid roller cam that had "lazy" lobes. It would be easy on the valve train and not require high spring pressure to control. It had 238/238 @ .050 and a .560/.560 lift (minus .020 lash) on a 114 seperation. For a 352 ci engine I wouldn't call it small, but it has incredible street manners.
Valve train stabiliy is a must. I spent the money and went with T&D shaft rockers. I check the lash once a year and the lash is always dead on. I like the ability to see if something is going bad before it takes out the engine.
I know checking lash on a marine engine is a PITA with the exhaust usually in the way.
I don't mean to muddy up anything here getting a little off the subject but I would imagine t&d's are more than likely to be determined the best and then we have Jessel and Yella Terra etc. I was told to get yella terra but my concern is do I wait until the builds are near complete. Is it possible one vs the other will be a better fit. In the past using stud mount rockers I remember using different rockers that provided a better fit and alignment although I wasn't using stud girdles either. Not sure what route to go. Not even sure what my options are with shaft mount rockers on promaxx heads.
Ive heard stud girdles can make rocker adjustment somewhat difficult as you tighten down girdle as it ties everything together it can change lash. I would imagine snugging everything down together in a sense may help or is it possible if you tighten down the girdle after setting lash and it changes then maybe you have the incorrect girdle or needs some mods. These are for solid roller sc engines.
Rookie did you try yella terra yet? I thought I recall you seeing them at the pri trade show and were convinced.
