Comp cams Short travel lifters BBC >
Old 12-12-2017, 08:37 AM
Rhythm and Blues's Avatar
Default Comp cams Short travel lifters BBC
Looking for opinions based on experience with the product. Thanks. COMP Cams Short Travel Hydraulic Roller Lifters 15854-16
N/A 572s; I talked to Gabe a tech at Comp and described the type of running I do; cruise between 3500-4500 and occasional run up to 5k
and he said most of the traits their solid lifters have the short travels will display as well, ie noise (not a big deal), not ideal for idling for extended periods of time, more frequent adjustment intervals, and showing the most benefits above 5500-6K rpm. His opinion was to run a std travel hyd roller which I'm inclined to agree with.
Rhythm and Blues is offline
Old 12-12-2017, 03:17 PM
Full Force's Avatar
I run short travel Johnson’s, zero issues, no noise, no adjustments, the reason for running them is deflection in Oliver above 600 lift and higher rpm stability to not bleed down, another plus is if one fails it basically becomes a solid and will have little lash, won’t cause other issues or enough slip to destroy things. I would run them only in a HR application as recommended by every single cam company I talked to when doing cams also, or go solid ...the only reason I didn’t go solid was checking lash would require taking exhaust off, new boat will probably get solids since I can pull valve covers with Stellings on
Full Force is offline
Old 12-12-2017, 04:12 PM
BEACH PARTY / HOLLOWPOINT
TomZ's Avatar
Received 1,323 Likes on 742 Posts
I used those lifters in my 454... I had a pair that went bad about ten hours into running (wouldn't hold oil pressure). I replaced the pair, and never had issues after.
I was running Comp 953 springs with my 525 EFI cam... the lifters would bleed down overnight, and make starting a bit hard. Once warmed up, there would be no issues until the next day... never really bothered me much, though occasionally, this would cause a mild pop through the blower. This could have been attributed to the oil I was running (Mobil V-Twin 20W50). I don't recall that this was an issue when running Rotella 40 WT (during break-in).
TomZ is offline
Old 12-12-2017, 04:25 PM
Thanks Tim, What kind of spring pressure are you running? Did you decide to run short travels because you run the motors up near the top frequently? I have heard of their traits of they bleed down and behaving like a solid lifter, that a positive. "deflection in Oliver"? I could go soild I'm actually more comfortable doing valve adjustments with solids than hydraulics. But, I'm running these motors pretty light 3500-4500 and looking to get some hours out of them. Solids are going to be harder on the cam etc etc. Kinda why I wanted to stay hydraulic. The boat wont see much above 5k-5500 and only for very short stints. I just talked to Nolan at Isky, they have the HPX like that sounds like a winner, Johnson bodies with isky internals. I liked what he was saying; great salesman, lol...
EDIT; Tim, you have 110ish hours on those now? Zero adjustments? I'm assuming you've checked tho.
Old 12-12-2017, 04:26 PM
Thanks Tom, you were using the Comp short travels or the Johnsons?
Old 12-12-2017, 06:03 PM
Full Force's Avatar
I think my spring pressures are 175 on the seat 550 open if I recall or something close to that I’ve never had to check anything as nothing has given me any problems Randy at Johnson lift or is a friend of mine he said just put them in and run them they will be fine I’ve had zero problems
Old 12-12-2017, 06:48 PM
Ok, no problems BUT you cant say for sure that the lash is right on after 110? I mean I do valves at 2000 hrs on the tug MTUs and you'd never know if anything is wrong but some do require an adjustment from tightening up. Know what I mean.
I will for sure give Randy a shout! Totally appreciate that lead Tim!
Old 12-12-2017, 06:55 PM
TomZ's Avatar
I was using the Comp lifters.
TomZ is offline
Old 12-12-2017, 08:51 PM
Full Force's Avatar
I have no issues or noise, have no reason to check lash they are still hydraulic, Randy never said I had to, I will ask though to be sure.
Old 12-12-2017, 10:13 PM
if the lash tighten,s up the valve seat is moving,it is not a lifter problem and adjusting the lash won,t fix the root cause of the problem.
mike tkach is offline
