Which head gasket to use BBC salt water
You'll read all kinds of opinions on this topic on the web. You'll find guys claiming they ran .028 quench, and never had an issue.
What is your method for measuring the deck height?
Geronimo36
On the zero deck, I'd check it to make sure before you do anything. I've seen some engines that are supposed to be zero decked but are 10 out of the hole because they've been milled a few times after the original build. Always best to double check all your measurements before assembly. Such an easy thing to check and only takes a few minutes. Why not just put a bridge and dial indicator on it to make sure. There should be plenty of youtube video's out there too.
Looks like I'm going with Cometic .040 MLS on a gen 5 454 rebuild 8.25:1, 4.28" is it better to go with a 4.32" bore or a 4.375" bore on the MLS gasket?
