Guess the new power game!
#31
#32
Finally made it out with the new engine and all went well! Still shy of two hours run time (probably an hour of that on the hose) so no wot runs but from cruising at 3500rpms it launches hard and keeps pulling where the previous engine fizzled out a bit. Pretty stoked with it.
The Holley Sniper works like a charm and I don’t miss fiddling with jets the slightest. Having a small issue setting the IAC to the correct parameters but it runs great.
Idle 13.5
cruise 12.8
WOT 12.5
Verifying AFRs with a wideband on the odd bank and the two sides are within .2 of each other, as near as I can tell.
Cold oil oil pressure at cold was a bit high for my taste at 75psi but eventually got back to 60 and 20 at idle after a moderately brisk run. 30w Brad Penn break in oil.
Idle 13.5
cruise 12.8
WOT 12.5
hogie roll (08-21-2020), SFOcean (07-08-2019)
