What Parts are need for 8.2 DTS engine??
Hello
I need some help to complet the new engine that i get today!
It was an 8.2 Mag HO DTS ,non Cat motor from 2016.
I can get engine and the zero effort 2 lever shifting from merc.
Now i need some harness,i think, and maybe an DTS modul!!??
Anyone can help what i need to bring this engine working condition??
Sorry for this questions,but it first DTs engine i work with!
Regards from Germany
Michael
Michael
I’m not an expert, but I don’t think you will be able to use the zero effort control. The engine you purchased is a fly by wire motor, it doesn’t use mechanical cables. The throttle and shifting signals are sent electrically to the motor. Pretty sure you have no choice other than purchasing a DTS control from someone like Livorsi and you’ll be all set. Good luck!
engine serial is the best start to this project.
The DTS actuator and harnesses can be purchased thru Merc. But again an serial number is the start for the correct info and correct parts for your engine set up. I can not stress hard enough how important engine serial numbers are especially more important for marine apps 2007 to current. Many systems changed thru out those years.
![](https://cimg8.ibsrv.net/gimg/www.offshoreonly.com-vbulletin/2000x1124/20181008_103033_17ca9daf702547b5f1874a902b697d81483afa4f.jpg)
![](https://cimg9.ibsrv.net/gimg/www.offshoreonly.com-vbulletin/2000x1124/20181008_103442_9c8df068973d7ef6f0c3e37746efc6396557ecac.jpg)
![](https://cimg9.ibsrv.net/gimg/www.offshoreonly.com-vbulletin/2000x1124/20181008_103456_37bcc6e4ff5d9e9ec16c943d958b41134f0f2b6c.jpg)
Hello and thanks.
Engine nummber is 2A506262.
8.2 Mag HO DTS
I have an sero effort DTS shifting from merc.
But i dont know what harness i need to make it work with the engine..
standart 14pin smartcraft harness has no connector for shiftung so i am shure i need something diffrent for this combination.michael
As soon as I saw the picture of the control you have, I knew you had a DTS control, which will work. Mercury used to make an older style Zero Effort control that was for mechanical cable operation. What you have will true.y be “zero effort”! I sure now that you posted your serial number, BUP will respond for the harness.
As soon as I saw the picture of the control you have, I knew you had a DTS control, which will work. Mercury used to make an older style Zero Effort control that was for mechanical cable operation. What you have will true.y be “zero effort”!�� I sure now that you posted your serial number, BUP will respond for the harness.
I hope so.Looks an special harness and maybe an dts modul is need!?
We add also an Ecomonitor and smartcraft gauges to the motor.
Michael
I can not remember the part number off the top of head. I will look it up when I get back to the office later today. Yesterday was really bad storms here and mild flooding. On my phone I can not look up some of this stuff.
Thanks a lot!
It has a bit time,as the engine swap is a winter projekt.I try to have all fitting parts to make it work before we start the work!
We will mount in an Baja 245! Michael
