10-71 fitment?? >
10-71 fitment??
10-71 fitment??
Old 11-11-2018, 09:09 AM
Default 10-71 fitment??
looking for some help. Will littefield 10-71 blowers clear the distributor on my tall deck 572’s without an intercooler? Also any ideas on real world parasitic loss on these bad boys?
rob vanharten is offline
Old 11-11-2018, 10:28 AM
Received 4,567 Likes on 1,315 Posts
Shouldn`t be a problem.
As far as loss , who cares. (not as much as you hear)
You`ll more then make up for any loss.
ICDEDPPL is offline
Old 11-11-2018, 10:39 AM
F-2 Speedy's Avatar
Received 3,165 Likes on 1,409 Posts
Aww, the ol ground strap on the sender trick, not seen that before but makes sense......enables you to use thread sealant without the chance of false readings @ the gauge
F-2 Speedy is offline
Old 11-11-2018, 01:24 PM
Actually it`s a 4psi warning switch for fuel pressure. Wouldn`t work at all without that ground strap. When the switch closes it completes a circuit via ground (negative)
But a good ground is also important with senders no doubt
ICDEDPPL is offline
Old 11-11-2018, 02:26 PM
Are these Littlefields in the pictures?
Old 11-12-2018, 09:42 AM
Bds
ICDEDPPL is offline
Old 11-12-2018, 11:54 AM
rv
Clearance of blower and distributor is mainly determined by intake stud locations. Each manufacture has them in a little different location. If memory is correct, BDS has studs located a little further forward than most.
rv is offline
Old 11-12-2018, 06:46 PM
Did you decide to go with 10-71s instead of Prochargers? Mama won’t be able to sun herself on the sundeck...lol
lucky cat is offline
Old 11-12-2018, 07:53 PM
Tinkerer's Avatar
Rob
I may have to stop up there and see what you are doing. I have been thinking on adding a power adder to my engine also.
Unless I can mount the M4 low or front mount it I will probably install a standard blower.
Tinkerer is offline
Old 11-12-2018, 10:23 PM
Stop in any time tinkerer! I am just putting the finishing touches on my shop so I can work in there year round warm, dry and bright. I have wanted to to go boosted for the last three years and keep going back and forth between procharges, roots, and 3.3 carb whipples. Deep down I think whipples are the best choice but they are spendy and almost never come up used.... I already have scoops on the sun deck but still won’t clear a roots with chillers. Thinking I may buy one whipple setup, dyno and reinstall, and then save some more money and hopefully by spring duplicate the first motor and be ready for boating come May! Switching to e85 so I will have some additional costs into making some fuel system changes and converting carbs over.
