2 different Quicksilver oils
Hey, ready to change the oil in my 96 Formula 303 with 502 mpi's. I want to put in Mercruiser Quicksilver 25W 40, but I see there is a regular and a synthetic blend. The synthetic blend is rated FC-W. Is there any advantage to using one or the other? I'm in SW Florida, so, boating season is still on and typically 70-80 degrees this time of year. The water temp is usually in the 60's & 70's now (not to rub it in with the northern readers, but just to know what the conditions that the boat is operating in).
Don’t know the differences. I use rotella t4 15-40 in engines. First sample tested good. Will be sending out the next change also. I do run merc high performance in the drives. I asked daryl at HRE about oils. He said as often as I planned on changing it the benefits of synthetic wouldn’t help much.
i use the regular in most applications,i don,t really think syn blend is worth the money.for me full synthetic or regular.
Dino oil is still good to use, in my engines I use synthetic Mobil one 15W-50. Last time I got it was at Walmart for around $23.00 for a jug. Drives, Merc High Performance. A lot of god oils out there.
yep,i have seen several high mileage engines develope oil leaks after switching to full synthetic.
Same engine (but 2000) . Used the regular 25/40 for the first year or two and then when the synth blend came available switched over to it. Considering going to the full synthetic 20/50 as at the Merc dealer there's not a whole lot of difference in the price between them . (believe it or not)
Without getting into the entire controversial oil argument they're all very good and you won't have any problem.
Never seen a motor damaged from any oil, only lack of maintenance
Being in FL I would just use straight weight no W needed.
I use Dino straight 40 in the 454, and Brad Penn straight 50 in the 509
Grey bottle is conventional...black bottle synthetic....was up thru this spring anyway.
yes. I run 20-50 VR1 conventional. Has worked great for me. Easy to find, price not bad.
