Valve guide clearance question
#51
if you are running the MKVIII fan then yes you are moving as much as possible. they move a ton of air no doubt. some of the guys that work on radiator and heat load testing did some tests for NASCAR and others and found that the black paint raised the amount of heat removed. most guys get by with leaving them aluminum because they have more cooling than they need so the difference would not be noticed. is this a single or double pass radiator? btw, you can get a rattle can of paint for bbq's that will hold up to the heat and not build thick and sticks to the aluminum well.
#53
#54
Here is the thread on his build. Not sure if he ever finished it. It is a good read, long read. 41 Upgrades
#55
let me preface this and say that I am not a ford guy (even though I have a 65 mustang, among other cars). but a problem is a problem and overheating is overheating no matter the brand. when you say it runs to the hot side is this in traffic, idling, or running hard? if any thing other than running hard it does not matter if it is 150 hp or 2000 hp because in traffic it is not making much power no matter what it is capable of. you have a fan that moves a ton of air so we can discount air flow unless there is some blockage. you have the biggest radiator you can fit (what is the car? looks like a fox body or whatever they call the next gen) either way you are out of real estate so the only other thing is flow rate of the pump. is it under driven? if so you may not be moving enough coolant at lower speeds. what are you running for coolant? with the air flow of that fan there is no reason to not find a way to keep it cool. I have that same fan on my test stand and the engine drops 50 rpm from the alternator load when it turns on. would love to find a fan that moves that much air but doesnt take 50 hp to power it.
#56
here is a good read, it deals with an LS based motor but the principles are the same.
Pirate4x4.Com - The largest off roading and 4x4 website in the world.
#57
#59
I'm running an electric water pump than flows more at low rpm's than the factory pump, 55gpm at idle. I tried just about every pump/pulley combination and have the car dialed in the best as of now. Also added Redline water wetter, tried different coolant/water percentages etc.It is what it is.
#60
that's the problem with a car that was engineered around a 250hp engine. you run out of room quick when you add stuff. probably no room in the front but maybe add a pusher fan to the help airflow at low speeds? I build a lot of hot rods (mostly street driven with moderate power) so I understand trying to fit bigger radiators, etc into a spot made for a radiator that cooled a 100 hp six cyl. it sounds like it stays around or under 200 so it is not running away with heat. most new cars run 210 to 220 and dont melt down so may not be worth worrying too much about.
