pan gasket MK IV >
pan gasket MK IV
pan gasket MK IV
Old 04-15-2019, 11:28 AM
F-2 Speedy's Avatar
Received 3,223 Likes on 1,439 Posts
Originally Posted by mike tkach
fel pro 1893 is the gasket that is correct for engines with stroker pan.it is a 4 piece gasket.
Thanks, big help as always
F-2 Speedy is offline
Old 04-16-2019, 10:00 PM
I gave up on the one piece gaskets as well. They suck.
MILD THUNDER is offline
Old 04-17-2019, 07:10 AM
F-2 Speedy's Avatar
Thanks for that incredible wisdom..........lol......
Old 04-22-2019, 11:45 PM
I never use the end pieces. I lay a bead of right stuff across both ends.
picklenjim is offline
Old 04-23-2019, 09:06 AM
Use the 4 piece 1893 and throw away the end pieces. Use Ultra Black , for the ends . Just like an Intake Manifold , those end pieces will leak .
dunnitagain is offline
Old 04-23-2019, 03:38 PM
F-2 Speedy's Avatar
I used the 4 piece, on a pair of 580's, I used a light coat of permatex on the timing cover and rear main cap added front and rear seals and let it set over night, next day added the pan rail sides sealed all 4 corners and snugged it up and hope for the best.
Old 04-23-2019, 09:40 PM
Like said, I tried to use the one piece from a local store on a Mark IV one time and couldn't get the pan on. Had to have been a mistake so I ordered another on-line. Same issue. RTV and the four piece from that point on.
f_inscreenname is offline
