Supercharger water intecooler feed line
GPM=I don't see allot of pressure coming out of the outlet hose. My setup doesn't see a lot of water pressure on the gage. I rebuilt the sea water pump earlier this year. Engine stays cool .
GPM- yes bravo 1 drive, T is in the pressure line off the seawater pump
I pulled the thermostat back out and will run the boat today...I'll let you know temps when i get back..
r,
E
r,
E
GLM- Took it out today and some magic must of happened between changing the alternator and removal of the thermostat.
MAT temps came down and the cooler was flowing alot better. Temps still got to around 140F after WOT runs but, cooled down.
No surging whats so ever. Boat ran fantastic. Best its run in a while.
checked inter cooler discharge while running and pressure increases as rpm comes up.
As most boosted situations it probably could use a little bigger cooler. or one that flows more.
r,
Eric
r,
Eric
Pro Charger doesn't want you to run a thermostat, the M4 cooler isn't the best. If your drive has a low water pick up similar to the Imco you can extend the opening to get more water to the motor.
