I am lost!!! >
I am lost!!!
I am lost!!!
Old 09-18-2019, 09:58 AM
Offshoreonly Advertiser
Mbam's Avatar
Is it puffing like with pressure behind it or just gently drifting out?
Mbam is offline
Old 09-18-2019, 10:28 AM
Default Smoke
Starts as drifting as motor warms it starts puffing
Raging Boater is offline
Old 09-18-2019, 10:38 AM
Default Video
937833eb-a38f-47e3-9c01-354
Old 09-18-2019, 10:44 AM
F-2 Speedy's Avatar
Received 3,168 Likes on 1,411 Posts
how many hours are on the engine ? are there valve stem seals installed
F-2 Speedy is offline
Old 09-18-2019, 10:45 AM
Default Hours
2-3 hrs, yes valve seals, however I was told a lot of performance motors don’t have them
Old 09-18-2019, 10:46 AM
Default Video
I can’t get the video to play
Old 09-18-2019, 10:47 AM
Default Curious
might be a little messy, but start it without the covers on
i honestly don’t know- what will that tell me?
Old 09-18-2019, 10:49 AM
Mbam's Avatar
Good chance you have damaged a piston/s and pinched a ring/s but i would expect a plug or two to show some oil
Mbam is offline
Old 09-18-2019, 10:50 AM
Default Tested
ted
checked plugs- perfect
compression test was dead on
also the motor runs normal it doesn’t skip or sputter at all
Old 09-18-2019, 10:59 AM
F-2 Speedy's Avatar
Does the MK IV run a lifter valley pan ? what intake are you using...Bowtie 10.2 block
