Bravo fresh water pump
I think the fuel pump will hit the block if mounted on the opposite side using the factory bracket. You would need to clock the assembly differently to clear which would require the fuel pump to be mounted on the water pump housing before mounting to the bracket in order to properly fill the oil reservoir.
