Holley HP EFI conversion >
Old 12-27-2020, 10:10 PM
  #131
Rookie's Avatar
Received 1,281 Likes on 622 Posts
Dan, In the Load Sensing box, do you run in Speed Density or VE mode?
Rookie is offline
Old 12-28-2020, 05:48 AM
  #132
if you have a MAF,mass airflow sensor,you can run ve,if you only have a MAP sensor,its speed density,I always use speed density.
sutphen 30 is offline
The following 3 users liked this post by sutphen 30:
articfriends (12-28-2020), ICDEDPPL (12-28-2020), Rookie (12-28-2020)
Old 12-28-2020, 06:43 PM
  #133
Rookie's Avatar
Originally Posted by ICDEDPPL
You don`t wanna do the latest V5 version?
Installed V5 tonight. Sent my custom global file to the ECU, configured my sensors, and set the dual sync distributor at 50° BTDC.
All recognized and working. Now just waiting on the coil harnesses. I'll hook up the fuel pump and relays tomorrow and check for fuel leaks.
Rookie is offline
The following 7 users liked this post by Rookie:
abones (12-29-2020), articfriends (12-29-2020), dykstra (12-29-2020), ICDEDPPL (12-29-2020), Panther (01-05-2021), SC288 (12-28-2020), sutphen 30 (12-29-2020)
Old 12-29-2020, 05:18 AM
  #134
articfriends's Avatar
Damn, at the rate your going we"ll be dynoing that biotch here REAL soon! is anything else holding you up?
articfriends is offline
Old 12-29-2020, 07:32 AM
  #135
Received 1,445 Likes on 804 Posts
What feeds the MPH gauge?
Wildman_grafix is online now
Old 12-29-2020, 08:40 AM
  #136
Rookie's Avatar
You can use any 0-5 voltage GPS speed sensor. I'm sure this would work.
https://www.autometer.com/universal-...tate=pg:2/ct:q
Rookie is offline
Wildman_grafix (12-29-2020)
Old 12-29-2020, 08:50 AM
  #137
Rookie's Avatar
Not really. Not paying attention I ordered the harnesses that ICDEDPPL posted on his receipt. Not knowing that my D585 coils used a different coil plug. LS Harness not IGN1A harnesses. They should be here this week.
2 558-312 harnesses for sale! lol $125ea shipped. https://www.holley.com/products/igni.../parts/558-312
Rookie is offline
Old 12-29-2020, 09:08 AM
  #138
I wonder if those harnesses will plug into a holley terminator X, I think these valve covers I bought need IGN1A coils (or D580's) (the mounting), If so, Ill take the coil harnesses for my E-85 motors Im building for the scarab
Old 12-29-2020, 10:07 AM
  #139
Rookie's Avatar
Running E85 I'd probably run the IGN1A coils.
Rookie is offline
Old 12-29-2020, 03:18 PM
  #140
13-1 548 your probably right
