Holley HP EFI conversion
#211
I'm sure you're still traumatized over it... Have you sought counseling over it yet. If not, reach out and I'll be there for you. You got my number...
SC288 (01-21-2021)
#212
I modified this one but I still find the engines are crooked going on .. the trans in the back is heavy .
But I will steal all your ideas and make one for myself .. I find myself bored with no engines projects, I almost wanted to build an extra long block.lol
F-2 Speedy (01-21-2021)
#213
Lol, I know how you feel. I went to the shop yesterday and had nothing to do. I walked around lost for a bit. Then I started thinking about the oil filter location. I had them on the blocks using a sandwich style thermostat. Simple and clean setup, but was a bitc# to get to the starboard filter. Had to remove the tails and 1 header. Not that bad to do once a year, just wanted to see if I could figure something else out.
#214
I`m in the boat a couple times a week looking for dumb $hit to change haha .
My filters are in the back but easy to get to
#215
I got a new project for ya , now that you got holley ECU`s , them screens and Holley gauges are pretty cool. I got rid of probably 20lbs of hoses and sender wiring . One data wire does it all now .
Common, let me spend your money!!
The following 2 users liked this post by ICDEDPPL:
Gimme Fuel (01-22-2021), sutphen 30 (01-21-2021)
#216
this is how I did mine,ex-nascar filter heads on modify merc alternator brackets w/ lift brackets incorporated.
#217
I've been eyeing the Digital dash panels, but they are pricey. I'd probably run my 10" tablets with Holley's dash setup first to see how I like it and glare. I run my navigation and stereo from a mounted 12" Samsung Tablet in front of the passenger on the dash. I'm working on setting up a wireless hub to the ECU. It's a little tough with out the 5v out from the ECU.
#219
https://www.ebay.com/itm/DC-DC-7-26V...-/203100160829
Rookie (01-22-2021)
#220
I think I'm going to first try a Raspberry Pi. I have a couple laying around and I am somewhat familiar with them when I was building a digital gauge cluster before I bought the Holley ECU's.
