Holley HP EFI conversion >
Old 04-17-2020, 11:25 AM
Rookie's Avatar
Received 1,281 Likes on 622 Posts
Originally Posted by kvogt
regulate at the end as AllDodge suggests.
That's how it is in my original drawing and pics.
Rookie is offline
Old 04-17-2020, 11:49 AM
If you can feed it from the front of one fuel rail, tie the rear of of the fuel rails together and mount the regulator on the front of the other fuel rail, you shouldn't have anything in the way of the distributor and will severely reduce the chance of vapor lock.
snapmorgan is offline
Old 04-17-2020, 12:50 PM
Yep, agree. That's how mine is in the photo above.
rvander68 is offline
Old 04-17-2020, 01:01 PM
Rookie, what size fuel lines are you running from thr tank to the rail, and what size return line to tank?
abones is offline
Old 04-17-2020, 06:17 PM
Rookie's Avatar
I'm running dash 8, which is 1/2 inch hose from my tank to my rails. My regulator was supplied with 2 -8AN ORB inlets with 1 -6AN ORB return. I'm running -8 for my return hose, but it is -6 ORB to -8AN male fitting.
Rookie is offline
Old 04-17-2020, 06:21 PM
Rookie's Avatar
The new doglegged rail mount worked great..
Plumbed my manifold today. Apparently the simplest was the easiest.
Rookie is offline
Old 04-17-2020, 06:23 PM
Rookie's Avatar
Also printed up fuel pump mounts and fuel filter mounts.
Rookie is offline
Old 04-22-2020, 09:49 PM
Rookie's Avatar
Hot off the printer, I just finished finished printing my 2" Throttle body spacers. Top 1" of straight into 1" of round full port transition.
Rookie is offline
abones (04-23-2020), Gimme Fuel (04-23-2020), hogie roll (04-23-2020), Panther (01-05-2021), sutphen 30 (04-23-2020)
Old 04-23-2020, 05:55 AM
looks great,,what 3d printer do you have?
sutphen 30 is offline
Old 04-23-2020, 07:04 AM
Those spacers look nice. A word of warning on your fuel rails though. I had a similar setup with the fuel regulator mounted to the fuel rail. The extra weight of the regulator caused the mounts on that side to break in some very rough water allowing the the injectors to come out of the manifold. This happened to me twice before I made some mounts out of stainless steel, the original mounts were made out of aluminum.
