Holley HP EFI conversion
#61
To be honest with you I have no idea. I haven't messed with too much alpha stuff. Had a 22' Chaparrall with a 330 Tempest and alpha that had no cooling issues. I do have a restrictor inside the bypass hose to the thermostat housing. It has a 7/32" hole in it so most of my water is sent through the engine.
#62
You don`t need an additional box to run coils.
HP and Dual sync is all thats needed.(and a couple subharnesses)
The following 2 users liked this post by ICDEDPPL:
articfriends (12-05-2020), Gimme Fuel (12-07-2020)
#64
Oh, I thought you were doing coil/plug.
Not sure on that then..I`m running 8 coils.
#65
#67
After doing 15 mins of research they are a "smart coil" that does not need a box. But it appears Holley has a coil driver module to drive a regular coil.
https://www.holley.com/products/fuel.../parts/556-150
Page 35 of this PDF
https://documents.holley.com/199r11031r.pdf
Page 35 of this PDF
#68
![](https://cimg5.ibsrv.net/gimg/www.offshoreonly.com-vbulletin/1140x2000/20190527_121409_resized_a66e3b297a5392637da7cd73c04dc816c81dc068.jpg)
Go coil per plug.
Better hotter spark, you can control individual timing on each coil if you wanted to .. I run a dwell map based on rpm... no need to fire those coils on full blast at idle..helps em live longer.
articfriends (12-13-2020)
#69
+1 on the coil for each cyl. if you can swing it, I would think it makes a lot of sense!
The following 2 users liked this post by abones:
articfriends (12-13-2020), ICDEDPPL (12-05-2020)
#70
I'll start looking for the best pricing on some D-585 coils. They seem to be good to 15# of boost. I'm under 600HP and NA.
The following 3 users liked this post by Rookie:
