Cylinder head/intake venting >
Old 05-10-2020, 07:33 PM
Rookie's Avatar
Received 1,281 Likes on 622 Posts
I actually have ground the webbing flush in that area on a couple of intakes and then drilled the intake. I usually drill from the back side because my intakes are removed.
Here is a pic of my thermostat. I do pull my inboard starboard header to change the filter. The extra 15 mins of inconvenience is worth cleaner rigging.
Rookie is offline
Old 05-10-2020, 08:14 PM
NautiB's Avatar
Rookie, what are the max temps your seeing with 165* Thermostats? The majority of what im seeing is 200*. My bearing clearances are tight & I have really good oil pumps so I expect even if its running up there in temp to burn off any condensation, I should be safe. That must be -10 hose?
Do you have any pics of your Dart intakes when you drilled them?
NautiB is offline
Old 05-10-2020, 09:23 PM
Rookie's Avatar
Originally Posted by NautiB
Rookie, what are the max temps your seeing with 165* Thermostats? The majority of what im seeing is 200*. My bearing clearances are tight & I have really good oil pumps so I expect even if its running up there in temp to burn off any condensation, I should be safe. ray: That must be -10 hose?
No pics of the Dart intakes. I'll look at my Stealths and see if they have the webbing removed.
Here is a pic of dash at cruise. I don't see over 180°F after the cooler.
Rookie is offline
NautiB (05-11-2020)
Old 05-10-2020, 09:44 PM
Sutphen 30, is that on a GenVI engine? Ive heard of doing that. I have MarkIV bow tie's.
I've done it on my gen 6's and on world and dart blocks.these were all moderate hp motors 6-700hp.all the water comes from offshore pick ups,no drive water supplies.
sutphen 30 is offline
NautiB (05-11-2020)
Old 05-10-2020, 09:50 PM
As you can see there is no boss to drill threw. The web there is in the way but just off center. I could either grind away the web, drill off center at an angle or get 2 new different manifolds, (rather not)..
if you want to put fittings in,,just grind a flat spot and drill and tap.losing rib won't effect anything.
NautiB (05-11-2020)
Old 05-11-2020, 08:34 AM
Here is a picture of how I did it. I used a Brodix HV2000 intake which had a pad for drilling and tapping. I use an IR temp gun to check temps front and back and they are within a couple of degrees. This is a crossover system with a thermostat and temps are super consistent from right to left and front to back.
ThisIsLivin is offline
NautiB (05-11-2020)
Old 05-11-2020, 10:07 AM
NautiB's Avatar
Sutphen, That was a concern I had. I like the intakes with prevision already there. Look good, preferred angle of the fittings & more meat to work with. But, well, I already have these. lol
NautiB is offline
Old 05-11-2020, 10:10 AM
NautiB's Avatar
Rookie, I appreciate all the visuals, very helpful. Thats awesome temp control & low cost to.
NautiB is offline
Old 05-11-2020, 11:45 AM
NautiB's Avatar
ThisIsLivin, Nice job, looks good! Is that -8 hose & fittings there? Im under the impression -4 is optimum but your temp consistencies are real good. Love the black headers by the way.
NautiB is offline
Old 05-11-2020, 06:50 PM
NautiB's Avatar
ThisIsLivin, by the way, what size are those FPS tees. 1/2" npt or 3/4"?
NautiB is offline
