Transom Assembly Questions
Can you tell by the pics if there is a spacer (g) pressed into the engine mount? I dunno if I have a second pair of spacers that I don't need to use or if I need another one in each side. Can you nornally pull that spacer out of the mount easily or does it press in and stay there?
Thanks!
Thanks!
There is only one spacer used on each side, as shown
tbev (06-26-2020)
