how to calculate blown engines carburation?
thnx
ps: no current engine for the moment.know the formula for non-charged.what is it for charged?
thnx
Thats easy BIG. Check with Dean at www.nickersonperformance.com he is THE man when it comes to blower carbs.
CFM or what size of carburetor is what I mean. If you are looking at how to set them up jet sizes etc there are many variables that need to be considered. If your guessing I would leave it to the experts.
This is out of an old BDS Blower book I have. What carbs do I need to run and why 2 of them?
The size of carb(s) or CFM required for a given application can be calculated by the following formula:
[(CID x RPM) divided by 3456] x [(Boost divided by 14.7) + 1] = CFM required.
The amount of CFM required will determine carburetor size and quantity. If you try and use a carburetor with less CFM than required, performance and economy will be greatly reduced.
ok i know the first part; volumetric efficiency ia taken at %100 in this formula...
according to this back4more should have 1250-1350 ...he has 1335 ..its ok.
paradigm : it looks like you are over-carburated..
why i am asking these questions : reason is :
i saw a 502 cuin blown engine 8 boost with twin 1050 dominators on top of it.its a marrine engine.rpm 6000.
any comments on this?
