95 502 Mag Mpi elbow & riser gaskets >
Old 12-29-2020, 09:13 PM
Default 95 502 Mag Mpi elbow & riser gaskets
Most likely a stupid question but, here goes.
Stock exhaust manifolds, risers & elbows. Took everything apart, has two different type of gaskets. One type has 4 equal oval openings which match the manifolds, elbows & risers. Other type has two oval holes & two small restricted holes in place of the ovals. Which would be preferred/correct? Thank.
smashm is offline
Old 12-29-2020, 09:42 PM
Well, after using the search function I found a thread from 2015 asking this exact question. It answered my question fully.
smashm is offline
Old 12-29-2020, 10:02 PM
SB
Received 3,277 Likes on 1,467 Posts
Open cooling:
One with 2 little holes is always placed against riser.
If spacer block is used between manifold top and riser, the 4 large oblong hole one is placed on manifold, and again, one with 2 small holes just under the riser.(top of spacer)
SB is offline
