Merc 420 spec's ??? What is it??
Dennis, Ive never done it but doesnt the Mark 4 blocks lifter bores have to be bored perpendicular to the cam centerline to use rollers? Thats what I was told a few years ago. maybe they have better roller lifters now.
I would be happy to have more than 450 hp per engine, but I also want maximum reliability without having to replace valve springs every season. That is a real hassle!! and broken engines in the middle of the season is not good either...
I hear that, been there, done that. I think the problems that people were having with the hp500 were the valve springs causing failure of the roller lifters. Crane and/or Merc screwed up and used a valve spring that was way to strong or had the wrong spring rate causing failure of the roller lifter. I would still find out about the mark 4 block and how well it accepts roller lifters before I considered that avenue. If you go the flat tappet route, break them in religiously (no idle time at all) and they will be fine for a long time.
When you are saying flat tappet, are you referring in fact to "hydraulic" flat tappets or solid ? I would think with solid lifters, the valves would continually have to be adjusted (bad in a marine setup), and higher spring pressures would be required??
Yes/No???? I do not really have an objection to hydraulics as I know they are reliable but rpms are limited also, are they not? What is the limiting rpm of hydraulics? flat tappet versus roller??
Oh yea, hydraulic flat tappets, you dont want to go solid unless you are after every last pony and they are a pain. Hydraulics are totally ok to 5500 rpm, maybe more I think. I dont really know, Ive run them to 5500. It mosly depends on spring pressures I think. You wouldnt really want to push your bravo over that anyway.
So, is it possible to reliably get 500 hp out of these engines and not be tearing them down all the time? That would be nice to have a cool 1000 hp in the Sonic!!
it's easy to get 500hp out of those engines and be trouble free. i had 400 hp MARKIV's. now they are right about 500's. i used a comp cams extreme 4x4 cam to keep the low end torque and still make good hp. redline is 5800 R's. 223int /234exh .544lift intake/ .564 exhaust with 111* LSA. clean the casting flashing up on the runners and the heads are good since they flow well already. i changed to EMI thunder from stock and have no reversion problems. my boat weighs 13,600 lbs and still has plenty out of the hole( not that i use it like that). don't believe rectangular ports can't make good torque down low. they can.
and if you use torquer 2 springs, no machine work is needed to the head.
Re: I agree with Formula 31
Originally posted by Dennis Moore
If you really want maximum power and fuel economy (you should use Formula 31's cam specs but) use a hydraulic roller camshaft.
The engine will idle smoother and make more HP with a roller camshaft than a flat based camshaft with similar specs.
Remember that all new engines come from the factory with roller cams (even stock automotive and truck engines) and durability is not a problem for them!
"Tinkerboater" had done this for guys around the area on their 454's and "JimV' offers it in his shop.
Dennis, you know, you are right about the synthetic oils being used in many of the everyday cars/trucks "grocery getters" with roller cams/lifters without problems. I didn't really think about that and have over looked that point. I always thought marine engines run under a harder load and more sustained RPM's---and they do, BUT I guess it (the engine) still doesn't know whether it is in a boat or a car---right? I think I have embarassed myself and get the dunce cap DANG!---what was I thinking??? And here I am giving guys advice. Take it ALL with a grain of salt gang!!! I think I'm going to go BURRY myself in my room for a while! Oh well, at least I have decided to use a synthetic in my roller cam equipt boat engines next spring. Therefore, I get to save a little face----not much, but a little anyway.
KAAMA,
You're a little hard on your self aren't you?
Read a couple of FAMILY AND PERFORMANCE BOATING MAGAZINES and fergetaboutit!
Dennis
KAAMA,
Dennis
