Got screwed on a boat ..Need help
Mine was the "Hot Boat" magazine test boat in Feb 89(?) then was used by Land and sea to do prop testing. I Purchased it at Holiday Marine in Bullhead City in 89. Is your the Burgandy and Red?
Anyway.... They were fun boats back in the day, Couldn't roll them, just kept biting in when they turned. All had 454's Ran a respectable 65-68 depending on Props.
Only problem (at least with mine and it could have been because it was a test boat, stripped motor mounts out of the Stringers, but it was an easy fix. Other than that, was a fun/great boat back in the day.
To my knowledge there is no gasket on any version of the bravo. Is the cable area leaking or when you pulled the drive and the petcock was depressed did it just leak gear oil?
Have you drained the oil to see what it looks like?
Also, if you bought a performance boat and get away with nothing other than an outdrive that blows up on you, you'll be the luckiest guy on this website!!!!
The following 7 users liked this post by seafordguy:
cigrocket (06-18-2021), Gimme Fuel (06-18-2021), ICDEDPPL (07-04-2021), jekyl (06-21-2021), rak rua (06-17-2021), resurrected (06-18-2021), tommymonza (06-18-2021)
So you've confirmed the upper shift cable is free. Is the lower shift cable free?
Title of thread is clickbait since no women pictures. LOLOLOL
The following 5 users liked this post by SB:
Cms51 (02-08-2022), Eddienel (06-18-2021), Gimme Fuel (06-18-2021), rak rua (06-17-2021), tommymonza (06-18-2021)
