Crank-mounted water pump?
#101
Anyone notice loss of water pressure or water temps rising. I installed them on my 12 m with NA 565’s. I like the way they plumbed in and easy access but noticed rising temps when I was on the pins. First time out last fall and only couple runs to do a shake down.
The impeller size is much smaller than traditional also.
#102
BEACH PARTY / HOLLOWPOINT
Mine dropped temperature when getting on them though I wasn't on the pins. Water pressure was 25+ psi at anything above 40 MPH. I'm closed cooled with idle temps right around 170, 150 running hard.
getrdunn (03-21-2023)
#105
#106
6k.
What I noticed on water temp gauge last fall was much above 4k temps jumped up quickly. I’ll find out soon. Although I love the concept just not certain they’re for my builds etc. possibly something else but I’ll find out. 330/365 under 5k likely perfect.
Dry to the tip should be pretty apparent water dumping but not. I believe the dumps at end of tips are 1/2”-5/8”
#107
Hey John,
Just checking in... Did you do get to the bottom of your rising temps? Curious to see how you made out.
I know it's already midsummer here, but I have not been out yet this season to test it out more. Weather, schedules, and a new driveway (with weather delays) have kept the boat on the hard. Next weekend hoping to be out and about.
#108
Hey John,
I did increase exhaust hose size to 1” so it’s not going to be a true comp. I almost left one side the way I had it.
weather here all messed up and lake mi just getting comfortable to run any kind of speeds without needing winter gear on. Lol
I do have two used only an hour of run time at best crank mount pumps for sale. I really like the concept and simplicity of install and impeller replacement of these. That’s for certain.
#109
To be perfectly honest though the one thing I never did was verify my water pick up hoses from boat bottom to sea strainers were 100% clear. Going to disconnect both on each side and stick a garden hose in them to be certain. Boat sat for a few years before last fall.
Abones gave me a heads up on that one! Mud bees etc?? You’d think would’ve cleared out after 10-15 min of running but rather be sure. I have two 2 1/4 inlets per side.
#110
Cool beans.
I was surprised to hear that you were having issues really. I could be wrong but my understanding is that once you’re really moving, water pressure is being provided by the movement of the pickups through the water with the pump helping things along. I know mine was maintaining good water pressure at 68 mph and 4700 but I wasn’t pushing her that hard either. If I started trimming and getting some more rpm, then maybe it would have shown something different. Time will tell. Max rpm for me will be 55-5600.
Hope you get out get to enjoy her!
