Dart Big M Block Questions >
Old 01-03-2022, 07:54 PM
Originally Posted by ICDEDPPL
First that`s going to destroy your outdrive, I don`t care what George says, bravo gears are small and you can`t change that fact.
Secondly, rod angles and whatnot , all that is $hit in stuff over 600ci.
I don`t like this plan at all.
Sorry, not sorry.
Dan hit the nail right on the head. Personally I wouldn't go any bigger than 565. You can stay with standard deck, rod angles are good and no goofy geometry on parts. I have 565's 9.3 compression efi's that make just a few hp shy of 800 hp. with a real good torque band. And on drives I wouldn't consider anything less than the scx. Already been down that rabbit hole. Any ways that's my 2 cents worth.
KWright is offline
The following 4 users liked this post by KWright:
articfriends (01-04-2022), ICDEDPPL (01-03-2022), IGetWet (01-03-2022), ThisIsLivin (01-04-2022)
Old 01-03-2022, 08:05 PM
Received 1,510 Likes on 831 Posts
KWright,
Noted. Soaking it all in.
Thanks. Brad.
(937)545-8991
Brad Christy is offline
Old 01-03-2022, 08:20 PM
Kwright,
Are those 10.2” decks or 9.8”?
Curious….
Thanks. Brad.
(937)545-8991
Old 01-03-2022, 08:25 PM
KWright is offline
Old 01-03-2022, 09:31 PM
Received 5,171 Likes on 1,467 Posts
Default If I`m spending your money
Big M block.
565ci
Machine for 55mm cam and .904 lifters.I believe you can buy them from Dart with those options.(so over kill lol)
Solid roller.
Tunnel ram
JE pistons
Molnar crank and rods.
Belt drive
Pro 1 heads.
Shaft rockers
probably run forever
ICDEDPPL is offline
Old 01-03-2022, 09:33 PM
Default or buy it already built from Shafiroff
Dan,
The breakdown on the short block is as follows.
Stage II
Rated For Up To 1250 HP
  • 4.500 Bore x 4.250 Stroke
  • 8.5-1 CR
  • Dart Big "M" Block w/Splayed Nodular Caps
  • Manley Fully Counterweighted 4340 Crank
  • Double Keyed Crank Snout
  • Callies Ultra-H Rods w/L19 Bolts
  • JE Pro Series Blower Style Pistons
  • 5115 Low Carbon Case Hardened Steel Pins
  • Hell Fire® 1/16 • 1/16 • 3/16 Rings
  • Clevite 77 "H" Series Main & Rod Bearings
  • Internally Balanced
$ 7,495.00
ICDEDPPL is offline
The following 2 users liked this post by ICDEDPPL:
IGetWet (01-04-2022), RedBoatFl (01-03-2022)
Old 01-03-2022, 09:57 PM
Rookie's Avatar
Received 1,324 Likes on 647 Posts
I personally would not put that much power in that hull. I don't know how much power someone has put in that hull, but I would not want to be the guinea pig.
Rookie is offline
Old 01-03-2022, 10:00 PM
This is about 90% of what you’re trying to do.
What you want is very custom, better find a reputable builder.
hogie roll is offline
Old 01-03-2022, 10:38 PM
SB
Received 3,397 Likes on 1,520 Posts
Watching his daughter racing right now. Of course I am.
SB is offline
Old 01-04-2022, 07:57 AM
Received 1,035 Likes on 520 Posts
I like the color of that motor,,looks sinister
sutphen 30 is offline
