The Right Prop
So, I refreshed my 26 Outlaw 496 HO and installed Whipple and DriveGuardian coupler. Won’t go into details in this post. The right prop is the topic here. I made several runs, after break-in, with a stock 28P and 26P Bravo I props. What is odd to me is both props run very similar. At WOT, the 28P is 5200 RPM and the 26 might be 5250. I cannot seem to over trim either prop, although the 26 does seem it start to get the bow a little lighter. I cannot get either prop to cause the bow to start porpoising or to see a noticeable drop in speed or rise in RPM beyond 5200. Both run 73.5 +/- .5. Rev limiters from Whipple set at 5450. Essentially, with either prop, you can just put the throttle on the stop, and trim full up, and it will stabilize at 5200 and 73.5. You can’t over trim, and you can’t hit the rev limit. Clearly, I believe, I need more bow lift and about 200-250 RPM, but it just strikes me as very odd. Intent is to have one of the prop labbed and tweeted to improve the two issues of RPM and lift, but I’m at a loss as to which prop to work. I’m baffled as to the similar performance of the two different pitch props. I’m throwing it out here to see if there are some simple answers.
26 Outlaw Bad Influence (02-20-2022)
That's a lot of slip on the 28"...about 21% so it isn't hooking up well...and around 15% on the 26"...which is better but still not ideal. Suggests to me that once hooked up, your RPM will be a bit lower but top speed higher. Do you have any idea how much power you are making?
Baja 252 Islander
Baja 252 Islander
that's a lot of slip on the 28"...about 21% so it isn't hooking up well...and around 15% on the 26"...which is better but still not ideal. Suggests to me that once hooked up, your rpm will be a bit lower but top speed higher. Do you have any idea how much power you are making?
700hp
getrdunn (02-21-2022)
About 63 MPH consistently. I’ve heard 80 will be tough without other outdrive mods, but am looking for high 70’s. Trying to be realistic.
