steering fluid coolers
I don't even think you run any steering without a cooler. Why would you want to?
I've done it. I Think I'm running them now...
Few threads about it.
Power steering Cooler, Do i need one
Yes, for years . No issues.
My temp indicator :
![](https://cimg5.ibsrv.net/gimg/www.offshoreonly.com-vbulletin/1500x2000/20220314_201049_resized_be41caf7d71eb28c125a8d34555a7c42cd4c5256.jpg)
My temp indicator :
SB (03-14-2022)
I was using the merc cheap cooler with tab that goes on belhousing for years. The tab cracked the body and started leaking, I bypassed it while on vacation and forgot about it for a few seasons, even at 6300 rpm, never foamed up or cooked pump, became unable to steer, fwiw, Smitty
The following 3 users liked this post by Griff:
This, I'm following.
I have a mayfair full hyd steering and have it connected to oem mercruiser cooler. But im no fan of running hoseclamps (even on low pressure side).
I would love to just get rid of it, Keep the info coming!
articfriends (03-15-2022)
I never knew. I just figured Merc wouldn't put it there if it wasn't needed. I have full hydro to 2 rams on 2 bravo ones. from imco, and just run the original cooler.
I use the Merc factory cooler, but none of my cars or SUV's have coolers. You got me thinking now, I will have to check the pump temp after cruising down the river for an hour.
