Roots to whippleish quesitons
Thanks for all the advice! So with the efi...would running the injector plate I linked earlier with 8 injectors and 2 TB's be a feasible option? Not sure what computer setup would be best for that application? Dominator? HP? I have the TB's picked out as well I'll get a link to those
Thats one way to do it .
or the set up I had that had everything built in, injectors and iac.
There`s a main unit and a slave unit .
HP ECU would be a great choice.
heres the part number i used ..
I have yet to really figure out the knock sensors.
It`s not as easy as it sounds, lots of 'noise' in a marine application, get it wrong , it starts pulling timing and there go your egts and exhaust valves.
SB (09-27-2022)
I see that holley now offers the terminator in a 2x4 setup which is essentially what you had...wondering if I should just buy that as an upgrade to my sniper and be good enough or change everything to a system like I listed...did you have any issues with the terminator setup?
I couldn't really tell from the pics or description but it almost looks like there is still only one IAC on the system which is dumb lol....Holley has a stand alone addon IAC I can use with the terminator but it just sucks its not built in.
I second wildmans question.....the whipple swap wasn't worth it?
