Anyone recognize this tool? Is it even marine related? I have no idea what it is
That piece locked the dudes doors so he couldn’t go boating. Bummer.
The following 2 users liked this post by articfriends:
DrFeelgood (02-13-2023), Smitty275 (02-13-2023)
Not 'bout the bellhousing, that the outdrive bolts too,..??
If So,.... Replacing the rear motor mount bushings is super easy, if you squirt a tiny bit of Quicksilver Power Tune on the rubber, before you try to push 'em into the flywheel cover holes,....
Now, I know that Power Tune is for the ole 2 stroke outboards, but I'm tellin' ya that this stuff makes rubber so slippery, that rubber pieces can be installed into / on to things that you'd think would never fit,....
The beauty of Power Tune is that it dissipates quickly after the installation, so that the rubber sticks in-place as it should,....
Don S,(God bless 'is soul) over at iboats taught me this trick( 'n many more) years ago, 'n I use it pretty much anytime I'm workin' with rubber bits,...
Tight fittin' exhaust boots,..?? they slide right into place,....
Drillin' holes in millbelt with a holesaw,..?? it cuts like butter,....
Merc rear motor mounts,..?? they almost slide into place, by hand pressure,.....
This is one of those "Ole Mechanic Tricks", I wish I had known decades earlier,.......
Ayuh,..... Just to be clear, this conversation is about the rear motor mounts in the flywheel cover, Correct,..??
BUT - the rubber mounts are in a metal sleeve, so it's metal on metal during install, so I'm not understanding how your recommendation would be applicable?
Interesting info there - yes, I was referring to the mounts that are in the rear engine cover, what would be a bellhousing in automotive situations, but is really just a flywheel cover for I/O applications.
