Aluminum cylinder head question AFR enforcer 335 >
Old 04-10-2023, 07:31 PM
  #51
Originally Posted by Bad to the bone
i went from iron World Product Grumpy head to Brodix 327 aluminum and gained 100 pounds torque and 80 hp on my blown 588's
And prob saved a bunch of weight too. Heard those are heavy heads.
xlint89 is offline
Old 04-11-2023, 04:51 AM
  #52
articfriends's Avatar
Which iron/ worlds did you have? I ran a set of the grumpy jenkins VR 310s years ago on a 540 with blower. Came up way short on dyno, when I had them flowed on the next refresh I found my answer when I saw how close to a stock head they flowed un ported. Sold them and bought AFRS.
articfriends is offline
Old 04-11-2023, 09:05 AM
  #53
Default Heads
They were original 800SC 345 Merlin Heads. The Brodix 327 heads added actually 100HP and 120 Torque which is surprising on the torque since we went up a notch on the cam to 680 so would have probably been higher torque if no cam swap. made 1000 lbs
Bad to the bone is offline
articfriends (04-11-2023)
Old 04-12-2023, 08:59 AM
  #54
Can stock iron heads achieve 550hp an on NA setup?
Joeyboost is offline
articfriends (04-12-2023)
Old 04-12-2023, 10:50 AM
  #55
SB
Received 3,325 Likes on 1,488 Posts
Crane 500EFI had iron rect’s (poss 2.25” intake valve though but not really sure) and 230/236 at 0.050” 114 lsa over .600” lift
So, the crane 741 equivalents should get you there 236/244 112 lsa over .600” lift
SB is offline
Joeyboost (04-13-2023)
