Hardin gen 7 sea water pump >
Old 04-16-2023, 09:37 PM
SB
Received 3,277 Likes on 1,467 Posts
OE Mercruiset has kits with wear plates and a tiny bit shorter impeller to use’m. I wrote a thread with this info here:
Boatfreaks
i know, you need to be a member to see it. Oh well, taje 2 seconds become a member if you want to see it. Lol
SB is offline
techman (04-17-2023)
Old 04-17-2023, 07:53 AM
Agree with SB
I use these with the stock housing:
https://www.mercruiserparts.com/merc...9-impeller-kit
I also replaced the back plate with the OEM plastic one which also comes with wear plates.
https://www.ebay.com/itm/29341263321...hoCcjAQAvD_BwE
Cheaper than the Hardin.
techman is offline
Old 04-17-2023, 08:33 AM
Just a little more info needed here …. What rotation the impeller must be reinstalled?? Im i supposed to turn it counter clockwise while pushing it into the pump ?!? Forgot to take pictures 🤦🏻‍♂️
Outlawmarc is offline
Old 04-17-2023, 08:49 AM
Doesn't really matter, it will flip to the correct orientation as soon as you spin the motor.
techman is offline
Helmwurst (04-18-2023)
Old 04-17-2023, 08:55 AM
i dont know why but my brain wants it to be in the correct position before startup 😂
Old 04-17-2023, 09:10 AM
From memory I believe it rotates counter clockwise lookin from the back. Search YouTube....hundreds of impeller change videos.
Once you jam it in there and lube it up, you can hand rotate the pump and you will see how it flip/flops depending on direction fairly easily.
Yes, I realize that last sentence sounds incredibly pornographic.
techman is offline
Old 04-17-2023, 09:12 AM
You can see the impeller orientation here. I just did the Hardin swap a few weeks ago
tmalone76 is offline
Old 04-17-2023, 09:17 AM
screenshoted 🫡🫡
thanks to all
Old 04-17-2023, 11:39 AM
Agree with SB
Did any OEM apps have a plastic backplate?
I thought they were all brass?
I did learn that there are wear plates for the back plate: Like this.
Although appears they used them on the air actuated drain system backplate that had a recess milled in it.
According to the pictures in the tech sheet.
There is a nice Mercury PDF tech sheet at the link you provided.
I thought this site had the ability to upload PDF's. I never seem to get it to work.
Anyhow if anyone is interested go to that impeller link and click where I screenshot.
cheech is offline
