575 dies when put into gear
Are those mefi 3's ?...........kinda strange its happening to both at the same time
I am WAAAY over my head here but I wondered what AIC was and looked it up. You said they idle fine, then that is probably not the problem seeing how that circuit(s) appears to be operating properly? So when they are both idling along fine, you put the port engine in gear and only that one stalls correct? Then the same for the other engine. Is it weird that both would have the same problem (AIC or whatever) at the same time? Is there something that runs both engines that could affect them? Bad ground somewhere? Btw, your setup.....wow.
is this happening first time out this year ? scan it and report back
