Throttle bracket? >
Throttle bracket?
Throttle bracket?
Old 06-06-2023, 11:05 AM
Received 1,494 Likes on 808 Posts
Default Throttle bracket?
Anyone know if these fit dominators. Looks like it will accommodate the 5.375 square but doesn’t say.
getrdunn is offline
Old 06-06-2023, 11:20 AM
I’m assuming not as I see both square & spread bore
getrdunn is offline
Old 06-06-2023, 06:36 PM
You are correct. It will NOT fit. The bolt hole pattern on a dominator is just enough off from a square bore that you can't drill a new pattern. Plus they're wider.
Smitty275 is offline
