Can you really regulate oil temp?
Be more specific with “When WOT it goes somewhere between 230 and 320.” Meaning, it reaches 320 at some point ? Or literally somewhere in between. If so, what #?is that?
Thank you.
Thank you.
SB, those are the last 2 numbers on the gauge. It never reached 320. If I had to guess it was 260-270.
I see by your other thread that you are taking the temp as it comes out of the engine so you dont know how much the cooler is doing. the cooler may be bringing it down to 220 but the engine is bringing it back up to what you are seeing due to tune or clearance, etc. I think I would find a way to test the temp going into the engine before condemning the cooler or thermostat
PQ290Enticer (06-12-2023)
Now, it's also important to consider where that temp is being read. If that's after the cooler, meaning, cooled oil, then it could easily be >300 before the cooler.
General consensus is to address oil temps if over 250 if using conventional oil.
If you're running it hard, and you are running synthetic oil, 260-270 isn't really anything to worry about. Oil is not breaking down at those temps.
I always like to know what temp the oil is going through the bearings....mine is in my pan so I know what temp the oil is coming out of the bearings but that's just me....I really could care less about the cooler temp I want to know what the motor is seeing as that's the important part in my opinion. For being relatively mild builds, I think you are either going to have to up cooler size or figure out where you have a restriction because personally I don't think your oil should be getting that hot. If you were supercharged I could see it I would think your oil should be relatively close to what the oil stat is.
Did you upgrade oil lines when you did your builds or are they still the small stock lines? Volume and flow have a lot to do with the temp as well....if the oil has a hard time getting to the cooler due to small lines or you have too little capacity the oil will heat up just because it can't get to the cooler and back fast enough to shed the heat. Just some things to think about.
Is it possible that the oil pumps I have are pushing the oil to fast through the system and not allowing enough time for the heat to be extracted? I don't have the number handy but they are Melling high volume pumps. I have no idea the volume but the pressure is running 50-60 lbs underway. I know from this site that others are using these and they are considered good pumps. Anyway, it's just a question.
this is why I would like to know the temp after the cooler. if it is down around 210-220 then the cooler is working but the engine is generating too much heat due to tune or clearance in bearings. right now you know what the engine is making for oil heat but not whether it is because the heat is stacking up due to a lack of cooling or the engine itself is generating a ton of heat due to tight clearance or lean tune.
The following 3 users liked this post by compedgemarine:
