Loose steering vs gimbal ring worn
I think my gimbal ring is worn and needs to be replaced, but I wanna make sure that it’s that and not the steering. So how do I know it’s not the steering when it comes to the outdrive being able to move back-and-forth by hand without engaging the steering on bravo 1? I can’t see the steering shaft so I can’t see if the gimbal ring is rotating on the shaft or not. The steering arm does not move either.
With drive trimmed up just a bit on trailer you should be able to grab the drive by skeg or the forward portion of gearcase. GIve it a good lift and you can feel the play in the upper and lower swivel. You can't really measure this but that will show the wear on the swivel. The arm that connects to the upper swivel can get loose as well, that is a separate issue but you need to isolate between the two symptoms. Both are wear issues that should be addressed if excessive.
Steering slop- isolate by holding the arm at transom still while checking wheel, it can be the cable or rack at help or swivel connection.
Well it seems you've already isolated it. If the arm #14, that extends through the transom is not moving yet the drive moves side to side then it would be that connection that is worn. Still possible that you have a worn rack at the helm which is easily addressed in comparison.
Reference this drawing-
https://www.mercruiserparts.com/brav...-thru-0m100000
item 1, 12 and 14. Pin 12 can wallow out 1. Trying to do this from phone but you can search worn gimbal for more detail. It really comes down to that you need to compare it to a few other boats and decide whether or not it's safe to operate based on the degree of movement a little slop is somewhat normal on a high hour boat a lot of slop is dangerous. Where in between those two is there a safety margin hard to say. Depends, to a degree, power speed etc. There are other where items between the drive housing and the gambling itself that can be worn but it would not show up as a great deal of motion.
-I’ll see if I can check the rack but none of this stuff I’m familiar with and with all boat stuff I just learn as I go.
Check the arm that goes to the steering. That pin wears also.
https://www.mercruiserparts.com/bam/...30967/1943/170
Please include hull, power, and hours. Take a very close look with an assistant to isolate what is moving and what is not.
There are drive experts on here, the questions below is for the smart guys with more experience in this area-
Is it possible to access bolt #17 and would tightening it perhaps help? If the play is there does the arm wear first and replacing it may correct the issue?
Check torque on nuts #25?
