HEI module
you run holley efi,right.is there a place for inputting dwell?
short story,I got a tune for a starting point on mefi4b,,little did I know,the tuner had jacked up the dwell 2-3 x more than a stock merc.I'd be going along and the engine would just die.finally stumbled upon that one,,never blew another module.did get good at replacing them while boat was under way.
SB (06-29-2024)
Hmmm I`ll have to check the tune for that
.. I could not replace the module . The rear 2 pins must be soldered? I cold not get them off.
SB (06-29-2024)
I thought it was a plug but it`s soldered together
https://www.summitracing.com/parts/m...CABEgIK7vD_BwE
that sounds modified at 15,,all the stock merc tunes I had were in the 3-6/7,,mine were 12-15,,it would cook the module,,merc has a big round rotor w/ fan blades on the bottom,,that helped some.
https://www.amazon.com/dp/B00AJVRHQU...roduct_details
stock 500 efi is 10.00 MS all the way acrossed the board
Ive actually never seen any stock mercuiser tune thats not 10 or higher.
also,I wonder if theres a translation difference betw mefiburn and actual merc tuning software.
I got em both started .. port needed the tune reloaded.. seems like RF or something is corrupting the files . Im getting both new distributers,, Eddie young says they give him lots of issues.
What type of shielding does the EFI computer have?
