2004 5.0 MPI/Bravo won't go past 3,000 RPMs. >
Old 06-28-2024, 07:29 PM
Originally Posted by CheckmateScarab
Winterized properly? Definitely do a compression check and better yet a leakdown test
Yeah, it was winterized properly. It did it last year as well and the mechanic didn't get to it...
jbozzelle is offline
Old 06-28-2024, 08:04 PM
Received 1,879 Likes on 944 Posts
Just need the kit with the right plug in cord Search Results for “techmate pro kit -update” – Rinda Technologies Inc.
Griff is offline
bajaman (06-29-2024)
Old 06-29-2024, 05:33 AM
^ This
As they say, you're just pissin' in the wind without a scan tool on an EFI engine. If you yourself were to purchase it, you could rent it out to recover the cost.
Baja 252 Islander
bajaman is offline
The following 2 users liked this post by bajaman:
Brad Christy (06-29-2024), Tartilla (06-29-2024)
Old 06-29-2024, 12:42 PM
Originally Posted by bajaman
^ This
The guy that owns the scan tool on the block is everyone's best friend...
Tartilla is offline
Old 06-29-2024, 10:37 PM
Judging from the sheer amount of boats at the marina that are all Mercruiser equipped I suspect I haven't stepped foot onto that block yet...
If I can't find the street I might have to become that guy...
Old 06-29-2024, 10:39 PM
^ This
Yep. Not my boat, so not my money. I'll see what my buddy wants to do though. I used to troubleshoot my old Ford diesel with a handheld programmer that showed damn near every parameter. Some good googling and common sense made it easy to see what sensors were faulty...
Old 07-02-2024, 08:14 AM
markt111's Avatar
you'll need a scanner to verify but sounds like the neutral safety switch, it will not allow the boat to rev over 3000 or 3500 (I forget) if in neutral, it is adjustable and mounted on the linkage... once you get over 3000 you may have other issues if it has not been maintained properly.
markt111 is offline
Old 07-02-2024, 01:34 PM
markt111, that sound like it matches his symptom pretty good! I was not aware of that but my boat is old school. Poor running would be associated with running out of power to not GET past 3000 ish rpm. Seems something else would show up operational wise if it were mechanical related to power output.
Can you supply some additional info on the safety switch behavior? Wonder if he could just bypass or jump it to test? May have to do it actively as it might check for that circuit.
BadDog is online now
Old 07-02-2024, 02:51 PM
The neutral safety switch, if it were bad would still allow it to throttle up? I know it will not start in forward, unsure about reverse. But the outdrive is mechanical, not electric shift.
Old 07-02-2024, 03:40 PM
If it was the neutral switch it would not even crank
In gear switch
AllDodge is offline
