Fuse box location on 1990 power play 290 enticer
Looking for the fuse box location? I assume it’s under the dash. I don’t see an easy way to access it, looks like I have unscrew and remove the large panel that goes from the dash to the floor. Thought there would be an easy access location but it doesn’t look like it. Anyone have any insight?
any help is greatly appreciated!
There's really no "fuse box". Everything is breaker protected on the dash. Are you looking for something in particular?
swellcraftman (Today)
Dbl post
Thanks for the help PQ, ah starting with nav lights, thought I would check the fuse before I started checking bulbs and corrosion. Have some other things that aren’t working either but it’s a long list 🤣
Should be on the dash. Good job checking the fuses first. I always spend hours working backwards to the fuse 🤣
