We hurt the 496.... >
We hurt the 496....
We hurt the 496....
Old Today, 02:52 PM
  #101
Received 5,002 Likes on 1,411 Posts
Talking
That`s not pig rich.. this is "pig rich"
ICDEDPPL is offline
Old Today, 03:10 PM
  #102
I would say that is oil
underpsi68 is offline
Old Today, 03:17 PM
  #103
Received 1,237 Likes on 686 Posts
Originally Posted by underpsi68
If that's the case, octane was a BIG factor.
Most of us at times have done something similar. In the end, it never saves money. It costs more money and time.
I would go with 80lb injectors if it was me.
UnderPSI,
I haven't ordered them yet. All options are on the table. Can you have too big of injectors, to where you can't dial them down at idle? Seems a legitimate question....
I'll discuss with the builder.
Thanks. Brad.
Brad Christy is offline
Old Today, 03:23 PM
  #104
You can have to big of an injector. I haven't found to big yet. I run 210lb injectors on my 353ci street car. I can lean it out as low as I want at any rpm.
Old Today, 03:33 PM
  #105
Dan, how do the cylinder walls look? Any indication of cyl washdown and scoring etc?
Tartilla is offline
Old Today, 03:54 PM
  #106
UnderPSI,
Thanks. Brad.
There would be an optimum injector pressure/duration.
60lb injectors at 0.6 BSFC would deliver 560hp at 70% duty cycle.
You're turning up the Pro Charger...you would be in that 560hp area.
One of your project goals is to streamline and bulletproof the fuel system. Having a buffer on the injectors to ensure there isn't a lean scenario may be job #1.
I wouldn't think you're running at 0.6 BSFC at WOT. Maybe 0.5 or 0.55.
That's at the rated pressure of 43.5psi.
60psi running pressure you may gtg with 60lb inj with sufficient buffer.
Tartilla is offline
Old Today, 07:11 PM
  #107
Rookie's Avatar
Received 1,305 Likes on 636 Posts
What he said. ↑ ↑ ↑
An 80lb injector is not a large injector.
Rookie is online now
