We hurt the 496....
#62
Ryan,
Just thinking logically (as opposed to empirically), I'd have to think there is less fuel flowing through the return line than the feed line. This would indicate to my layman's lizard brain that the return line wouldn't have to be as big as the feed line.
But this is why I'm here asking questions. I don't want my lizard brain to farq this thing up.
Thanks. Brad.
Thanks. Brad.
Griff (09-09-2024)
#63
I'm not sure why the Ys and Ts would be an issue, but I certainly don't want to build in any inherent problems. I'm going to be meeting the builder that is doing the work this afternoon to discuss details of the build, and this is among the topics we will cover. He is aware of my interest in building this fuel rail.
I could potentially configure my rail something similar to yours, but flipped front to back, with the feed and return lines coming in from the front of the engine instead of the back; feed on the port side, return on the starboard (reasons) and the connector on the back of the engine. It would actually mean shorter lines from the pump to the cooler/tank. Any issue with doing that?
Thanks. Brad.
#64
I am trying to think also why would the return be larger?
Ryan,
Thanks. Brad.
Thanks. Brad.
#65
You are very likely correct.
I will be welding AN male fittings to the ends of each of the two rails. The entire construction is going to be stainless; 316 seamless tubing and 304 fittings. Rigging fittings will have to be female.
Trying to develop as much of a "drop-in" replacement as I can from my wheelhouse, the two separate rails will be different, having to deal with the coolant reservoir tank and the offset of the cylinders. One will be a bit longer than the other, and have an angled end to accommodate the coolant reservoir. I'll post an AutoCad screen grab of the basic idea shortly.
Thanks. Brad.
#66
Hey Brad as a salt water boater just to let you know 304 will rust in salt air. Just in case you want a larger customer base.
CompedEdge,
Thanks. Brad.
Thanks. Brad.
Thanks. Brad.
Thanks. Brad.
#67
Just a factor: the return line is unpressureized after the regulator.
Similar to the concept of a remote fuel pump feed hose needs to be larger than what the pressurized fluid post pump would require. Unless there is an in tank lift pump to feed the main pump.
Wildman_grafix (09-10-2024)
#68
Only commenting on the rods because I don't know much about the rest of these particular engines, but I know a lot about rods.
Most H-beam rods of all brands are Chinese rods that are pretty inexpensive, and I could tell you the factory that most come out of. They are fine, they work, they are entry level and prices as such. I'm not sure why they have been such a staple and go to in the V8 world for so long, but I think they hold up well in lower rpm NA applications....low boost applications, etc.. In higher end motorsports engines, we don't use H-beam rods. They simply won't last, even in something like 300m we will see the H start to twist and eventually fail, so we run I-beam rods of higher in various materials and we can put them through a LOT more abuse.
Here is one of the strongest steel rods that you can put into an engine. Relatively Inexpensive, and yes also made overseas. I put 300-400hp per cylinder through these things and its hard to hurt one. This is what I'll rebuild my engines with when the time comes. I've put them in hundreds of engines.
Home | Boostline Connecting Rods (boostlineproducts.com)
Formula 353
Merc Racing 540s
Formula 353
Merc Racing 540s
TeamSaris (09-09-2024)
#69
I’m aware that 304 is less corrosion resistant than 316, but I have yet to find 316 AN weld-on fittings. I could make them, but that’s a PITA. Something to chew on.
Thanks. Brad.
#70
At more than double the cost of Molnar, and more expensive than Oliver, these rods are anything by “inexpensive”. If I were going to blow my budget, I’d just go ahead and get the Olivers. Molnar rods, while indeed forged in China, are not coming out of the same foundry as other rods. Tom uses a specific foundry that follows his exact specs for both metallurgy and tempering (Tom Molnar was the chief metallurgical engineer at Oliver before starting his own company), and are then finished in Michigan. I really like what I’ve read from the various forums I’ve stumbled across (mostly street/drag), and I’m reassured by the builder that they are more than adequate for my application. The Molnar-specific ARP bolts, and the engineering behind them, are just icing on the cake.
Thanks. Brad.
87MirageIntruder (09-10-2024)
