We hurt the 496.... >
We hurt the 496....
We hurt the 496....
Old 09-09-2024, 03:37 PM
  #71
DRAG's Avatar
Drag,
At more than double the cost of Molnar, and more expensive than Oliver, these rods are anything by “inexpensive”. If I were going to blow my budget, I’d just go ahead and get the Olivers. Molnar rods, while indeed forged in China, are not coming out of the same foundry as other rods. Tom uses a specific foundry that follows his exact specs for both metallurgy and tempering (Tom Molnar was the chief metallurgical engineer at Oliver before starting his own company), and are then finished in Michigan. I really like what I’ve read from the various forums I’ve stumbled across (mostly street/drag), and I’m reassured by the builder that they are more than adequate for my application. The Molnar-specific ARP bolts, and the engineering behind them, are just icing on the cake.
Thanks. Brad.
All good, was just a suggestion. I sometimes forget the retail end of these things since I buy in quantity or make our own.
Formula 353
Merc Racing 540s
DRAG is offline
SB (09-09-2024)
Old 09-10-2024, 05:09 PM
  #72
Received 1,237 Likes on 686 Posts
Hey Brad as a salt water boater just to let you know 304 will rust in salt air. Just in case you want a larger customer base.
Wildman,
I’m aware that 304 is less corrosion resistant than 316, but I have yet to find 316 AN weld-on fittings. I could make them, but that’s a PITA. Something to chew on.
Thanks. Brad.
Wildman,
OK, OK... You talked me into it....
I'll be making the AN weld bungs from 316 round bar. This means the entire assembly will be 316 stainless. I have the tubing in hand, and it almost looks polished (I did not order the polished material). After passivation, they should look pretty nice.
We are actively working on fixturing components as I type, and I will be starting on assembly members shortly. It's on the slow boat from China, but it's coming together.
This is a basic representation of what it will end up like.
The mounting tabs will be there, as well, I just didn't feel like taking the time to draw them out for this pic.
The hex on the #2 cylinder injector cup is an AN fitting welded on top of the injector cup. My intention is to attach the feed line to the AN fitting near the #1 cylinder, plumb the two rails together at the rear of the engine, and the return line will exit vertically from the #2 cylinder injector cup.
Thanks. Brad.
Brad Christy is offline
Old 09-10-2024, 07:13 PM
  #73
Received 1,462 Likes on 814 Posts
Lol
Wildman_grafix is offline
Old 09-11-2024, 02:55 PM
  #74
Guys,
So, I've managed to snag a Holley HP ECM and harness, used, through the builder that's doing the work. I will not be horse collared by the PCM555 moving forward. Which means I will be brooming it. He is also going to be doing a custom grind cam for me that will render some of the benefits of the ProCharger, closing the gap between the OEM and the Raylar 211 cam, while still avoiding any reversion. So that brings on a question...
While I was contemplating the Raylar cam, I was told that I could swap the cam without worrying about the lifters, due to their being roller lifters, so I'm assuming a good shape used cam could be used in another 496 with the same lifters. Would there be any interest in a PCM555, with or without harness, flashed with a Whipple stage 2 tune, and a (assumingly) good shape 496HO cam? This seems like a prime opportunity for someone looking to upgrade their NA base MAG.
I also have a TechMate Pro that I will no longer have any use for.
I will be posting these items in the swap shop when I get back from next week's vacay, but I wanted to get a feel for the prospect.
Thanks. Brad.
Old 09-11-2024, 06:26 PM
  #75
Received 5,002 Likes on 1,411 Posts
I havent followed the whole whole thing but .. I had Molnar carnks and rods and they held up great.
How tall is your hatch ?
How much $$ is it going to cost to rebuild these in total?
Reason I ask is , I`m getting some Eddie Young Engines and mine are for sale.
Spent $3k per engine on head work, everything new besides the valves. Valves back cut, all new guides, valve job, springs retainers, etc etc
They will be converted to Holley to solve the distribution and timing issue.
Coil on plug
$22K complete .
The engines are tall deck Dart blocks, with new JE positions. The block has never been bored.
The rods are Carillo, and the crank is from Lunati. The crank was re-done by Lunati directly on the current build and set with 2- keyways for the blower pulley.
With a change of fuel, and a change of the lower pulley, 1300-1350 is what they would run.
He had them dialed back to the current setting for ultimate reliability, and loves the current performance level.
15-20 hours max on the engines since they were completely redone to the current specifications.
* The heads are Dart Pro-1 that are ported
* The ignition controller is a MEFI 4 with Daytona sensor controller and coil.
* Isky solid roller cam with T&D shaft. 1.7:1 rockers
* Positions are JE
* Block is a Dart tall deck
* Rods are Carillo
ICDEDPPL is offline
Old 09-11-2024, 06:29 PM
  #76
I have miles of receipts.
probably a little much for your drive lol
ICDEDPPL is offline
Diamond Dave (09-11-2024)
Old 09-11-2024, 07:45 PM
  #77
Offshoreonly Advertiser
Mbam's Avatar
Wildman,
Thanks. Brad.
These are my go-to guys for 316 stainless fittings. Not inexpensive but they have a nice selection.
https://www.titanfittings.com/
Mbam is offline
Old 09-11-2024, 07:46 PM
  #78
Dan,
I appreciate the offer, but, yeah…. WAY too much for our Bravo 1. Hell, I’m pushing it pretty hard, as it is. Additionally, there is no farqing way I’m either getting one of those under my hatch or talking the wife into spending even half that for one of them.
Honestly, I’ve added up the major buys involved in this; pistons, rods, cam, head gaskets, Swaintech TBC on the pistons, machine shop cost, builder’s fees, etc…. I think I’m back together for somewhere between $5K and $10K. What I’ve listed so far is still just under or right at $5K. The Holley HP and harness are actually a net gain, money-wise, accounting for selling the 555 instead of having to send it to Boos or Whipple for tuning.
Thanks. Brad.
ICDEDPPL (09-11-2024)
Old 09-11-2024, 09:11 PM
  #79
I`ve never seen a bill that low for a rebuild but I hope that
it works out for you !!
ICDEDPPL is offline
Old 09-11-2024, 10:32 PM
  #80
Dan,
Oh, I’m not so naive to think that budgets don’t blow up in the dead of night. I’m fully aware that battle plans rarely survive initial contact with the enemy.
Adding up what I’ve mentioned, and adding in the 600SCI oil cooler that has been suggested to me, and a new fuel pressure regulator, assuming what the builder told me for the machine shop cost is correct, I’m at $5600, engine out, rebuilt, and back in, parts and labor. This does not include new valve springs or gaskets other than head gaskets. The labor cost may increase a bit with the addition of the Holley HP, as I understand it’s not a direct plug-n-play on the 496, but can easily be made to work. I’m sure there will be other sundries that will add up. But I’m hoping to keep it under $10K. That said, I am actively combatting scope creep tooth and nail. There is a ton of stuff I’d LIKE to do.
Thanks. Brad.
The following 2 users liked this post by Brad Christy:
Padraig (09-12-2024), sonicss42 (09-12-2024)
