Roller Rockers
#41
Hey guys if your interested in purchasing some Harland Sharp rockers check the thread I've posted on general discussion area:
Bobby Daniels: What do you mean scorpion is a private label harland sharp?
#42
These Scorpian brand rocker arms are look slightly different that the Harland Sharpes. The Scrorpian's are a little more streem lined and shaped/resemble a little more like a Crane rocker.
#43
Originally posted by KAAMA
Doug, is there anymore you can tell us about the Scorpian brand roller rockers for a marine application? Anyone out there with big power that you know using the Scorpian roller rocker arms with good success? While you were visiting the Scorpian plant did they give you any reasons as to why their roller rockers might be better than Crane's or Crower's or Harland Sharp's or any other brand? Just curious. Thanks
Mark/KAAMA
Mark/KAAMA
#44
CRANE GOLD AND HARLAND ,SCORPION ARE FFOR MILD OR MID LIFT CAMS THEFORE MID H.P MOTORS ,JESSELS AND T&D SHAFT ROCKERS ARE WHAT THE BIG BOYS USE .
IF YOU DON'T WANT TO SPRING FOR THESE ,THE COMP. STAINLESS OR CROWER ARE GREAT MUCH HEAVIER ROLLERS AND BEARINGS ECT AND LIGHTER OVER THE VALVE THAN ALUIM.
ALWAYS SPEND ALOT OF TIME CHECKING USED ROCKERS ,,,ITS BAD TO HAVE A BEARING DROP OUT IN THE MOTOR ,
I HAD A POST ON HERE WITH PRICES ON ALL ROCKERS AT A SPECIAL PRICE,PM ME IF YOU NEED SOME ROCKERS
zimm17
5
05-25-2007 09:24 PM
