Trying to get a little more power out of my 572
KAAMA,
The numbers are dyno#'s.
[email protected]: 248/254
Intake:brodix hv2000 if that makes any sense.
The heads were ported by the engine builder.NOT sure how much work they really have. thanks KAAMA.
Wil Ros,
Call ( CMC ) Compition Marine Center
ask for Chip.
Awesome power
572 ci 760 hp low compression 89 octain
beat it like a step child as Chip said.
St. Charles Mo.
636-946-1182
Good Luck
Cougarman
ask for Chip.
Awesome power
St. Charles Mo.
636-946-1182
Good Luck
Cougarman
Geronimo36
Will,
There was a boat in the area (Apache Warrior). He was running 572's and was making about 750 HP. He was runing Aluminum Heads, Solid rollers, and a tunnel ram intake. A friend of mine built the motors, not sure on the specs though.
Point is, you should be making much more power. I can make that much power with a 502 with off the shelf parts.
How would you make your 640hp 502 ?
![Roll Eyes (Sarcastic)](/forums/images/smilies/rolleyes.gif)
I know what it took to make 625hp out of a 502 with 8.51cr .
Geronimo36
From my experience on a friends 502 with Iron Oval Port Merlin Heads, and a .634 cam made over 600hp. Switching over to a good aluminum head and a little bigger cam and i guarantee it would be right up there.
All you need to do is turn more rpms and you will get the power you want. Although I would not recommend this with a stock bottom end it can and has been done.
That is pretty much how I did it, but my Merlins where ported and it took a solid roller and on the dyno with 87 octane at 5800rpm it made 625hp
I don't consider ported Merlins and a solid roller "off the shelf"
My current 540 is making close to 700hp but it took a solid roller to do it and that has caused some issues (lifter breakage)
