Trailer bunk replacement question.
I plan on replacing my trailer bunks first thing next spring. Before I put the boat in storage I measured the bunks and plan on having the new ones made so it will be an easy change out. The current bunks are 2"x4" and 2"x6" carpeted boards. My question is what kind of boards are these? Are they just standard or treated boards or is there a special marine grade board? I plan on getting the materials soon and want to get the right stuff. Thanks
Charter Member #71
Use pressure treated doug fir if its available in your area. If not any pressure treated will work. Dont forget stainless staples and hardware, and marine carpet. If you need to cut them be sure to re treat the cut ends. Not as good but better then nothing.
Dan
Dan
I used pressure treated doug fur for mine.
I bought the wood and let it dry out for about a month inside then painted it with rustoleum to help seal the wood.
Instead of carpet I used "TIE DOWNS" bunk glide-ons.
There a slippery type molded plastic cover that is made for different size bunks. I never liked the idea of the hull sitting on wet carpet all the time. Just a thought. They worked very well for me.
There availible from "overtons" or even cheaper check out www.outdoorsuperstore.com I just looked now and they have them on sale for 2x4 or 2x6 bunks. Search under "self center boat glide ons. These things do every thing they say. They also centered my boat perfectly every time.
My trailer bunks need replacing too. Being that the Mantex factory is here in Michigan (Lansing), I am going to see if it will work as trailer bunk material as well. I guess it is supposed to work well with staples, nails, screws, adhesives, etc.
You can even take it a step further with the staples and use MONEL staples, which are absolutely RUST-PROOF.
I actually used cedar on my 8' outer bunks last year. The only problem is that it does not hold screws as well as the more dense woods, so don't drill the holes any larger than you have to and fill them with liquid nails before putting the screws in. I think the cedar dries out quicker than other woods. This year, I'll be replacing my 12' inner bunks with pressure-treated wood because it is too hard to find a reasonably straight piece of cedar in a 12' length. Getting straight cedar is critical becuse a 2x6 piece of cedar actually measures 2" x 6", so it's really stiff and hard to bend into place.
I'm sure someone will tell me all kinds of reasons why I should not have used cedar, but I thought I'd try it, and it's working great so far.
1 Post
Has anyone ever tried the synthetic wood used for decks and floating docks? I would imagine you wood (no pun intended puder) never have to replace them as often. Better yet if you can find starboard which is very costly that would last forever.
synthetic wood has very little flexural strength. Needs additional support in flooring applications to avoid sponginess when you walk on it. I'd think that real wood would be a much better choice.
